Dynamic Blocks Forum
Flipping a Logo within a block, without mirroring it.
1 REPLY 1
870 Views, 1 Reply
I'm trying to make a Dynamic Block for handicap parking spaces (attached).
I have a flip action so that I can switch the direction of the linear array.  The problem is when I flip the block, the handicap logo is mirrored (obviously....).
Is there a way to mirror just the location of the logo, instead of mirroring the location AND the logo?
Would it be possible to make a block with the handicap logo and lock the X scale value to 1 ?...
Any help would be appreciated... worst comes to worst, i'll remove the flip action and replace it with a rotate action.
Thanks.
1 REPLY 1
jason.estas
G'day,
Please refer to attached DWG.
As you may notice there is a move command on the disabled symbol. When using the flip command instead of selecting the disabled symbol, select the move parameter instead. This will stop the symbol from mirroring.
Jason
”Boost
”Tips
”Services
