Dynamic Blocks
Valued Contributor
Message 1 of 5 (223 Views)
Accepted Solution
Field not showing up in block
223 Views, 4 Replies
10-04-2012 06:37 AM
I'm following this tutorial, trying to create a field in a dynamic block to show the length of a line.  If I have the attribute's "constant" value checked, the field shows up in my drawing as "Length: ######."  However, when I uncheck the "constant" checkbox, the field doesn't show up at all, even after I run "UPDATEFIELD" and "REGEN."
I'm using AutoCAD Mechanical 2009, SP2
-Using Autodesk Inventor Professional 2012
ojuris
Message 2 of 5 (213 Views)
Re: Field not showing up in block
10-04-2012 07:13 AM in reply to: nannerdw
could you post the block?
Valued Contributor
Message 3 of 5 (211 Views)
10-04-2012 07:21 AM in reply to: ojuris
ojuris
Message 4 of 5 (204 Views)
10-04-2012 07:43 AM in reply to: nannerdw
use command   ATTSYNC   to refresh your attributes, when You change them in block
after that all is OK for me in Your block
Juris
Valued Contributor
Message 5 of 5 (203 Views)
10-04-2012 07:44 AM in reply to: nannerdw
Thanks.  That worked perfectly.
I ended up just using a dimension for this block, though, so it would update automatically.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
