Dynamic Blocks Forum
Export to Model
1 REPLY 1
leaveAlone
444 Views, 1 Reply
Export to Model
I have AutoCAD 2013 and usially use in my work dynamic blocks with wipeout, e.g. valves, pumps and others.
So, few days ago I found that I cannot export my drawing from layout to model space. Everything is exported except wipeouts.
Is it something about new Autodesk politics or what? AutoCAD 2010 still works fine with the same drawing.
Examle.dwg is attached.
1 REPLY 1
hwalker
in reply to: leaveAlone
I have not got 2013 and I only use LT so I can not help totally, but here are some questions.
1. Are the wipeouts parts of the block or are you placing them on afterwards?
2. Have you tried using chspace to change the block from paper to modelspace?
Howard Walker
Left Handed and Proud
”Boost
”Tips
”Services
