Dynamic Blocks Forum
Dynamic blocks able to be table driven???
4 REPLIES 4
665 Views, 4 Replies
To anyone who may be of some help:
Can you make a dynamic block table driven, such as from an excel table??
For example: lets say you have a dynamic block with parameters/actions set up that allow you to set the width, length, height, distance from edge, # of object arrays, etc. Rather than grabbing each grip and specifying the desired dimension, can you make it so the dynamic block is table driven? such as, where you might have a list of desired dimensions (say in excel) and you want to quickly input them into a table in autocad, so that the dynamic block will adjust to those dimensions???
4 REPLIES 4
Charles_Shade
That will need to be a programming fix.
It may be possible just not OOTB.
in reply to: Charles_Shade
Thanks for the reply...so it looks like im in no luck unless I program something myself Smiley Frustrated
what is OOTB?
out of the box
Charles_Shade
”Boost
”Tips
”Services
