Dynamic Blocks Forum
Dynamic block with move in two different directions
4 REPLIES 4
stran1u
1676 Views, 4 Replies
Hey,
I'm trying to make a dynamic block that moves to lines in opposite directions with one grip. currently I'm just using a seperate move action for the other line i'm trying to move. I've attached the block to further drive the point home as I'm having a hard time articulating my thoughts.
4 REPLIES 4
jarredmonday
in reply to: stran1u
I'm assuming this is what you're looking to do? What is the application for the block?
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
stran1u
in reply to: jarredmonday
Would you be able to explain how you got the ends of the brackets to move without them changing size.  I'm just curious for future reference
Charles_Shade
Click on Stretch3 and in the Properties window look at the Distance multiplier.
In this case setting it to a negative causes the end to move in the opposite direction.
This is one of several ways this can be achieved.
jarredmonday
Saved in an earlier version.
”Boost
”Tips
”Services
