Dynamic Blocks Forum
Dynamic block with alternating objects
8 REPLIES 8
Message 1 of 9
976 Views, 8 Replies
I'm currently creating blocks for our office library. One of these is a grille with some apposed blade dampers on it. I'm trying to set up an array that will duplicate the apposed blades as I change the length of the grille. However, it will only copy the blades in pairs, not singlely one after the other. Ie, the blades are 100mm apart, and in a / \ pattern meaning that each instance of / or \ 'should' duplicate every 200mm. Except when I lengthen the block by 200mm it won't duplicate untill I've gone double the distance (400) when it gives me both / and \.
Does anybody know of any solutions? Or if it's possible?
8 REPLIES 8
Message 2 of 9
ojuris
hi! Check this version Regards Juris
Message 3 of 9
in reply to: ojuris
Hi ojuris.
Please explain? I'm using autoCAD LT 2011 if that's what you mean?
Message 4 of 9
ojuris
no, I don`t mean that I attach file, but where is it - i don`t know I`ll try to draw again ...
Message 5 of 9
ojuris
try to attach new file
Message 6 of 9
ojuris
in reply to: ojuris
I can`t attach file
Message 7 of 9
in reply to: ojuris
So I see. Can you describe what you did?
Message 8 of 9
ojuris
in reply to: ojuris
Message 9 of 9
in reply to: ojuris
Thanks, that works.
”Boost
”Tips
”Services
