I'm currently creating blocks for our office library. One of these is a grille with some apposed blade dampers on it. I'm trying to set up an array that will duplicate the apposed blades as I change the length of the grille. However, it will only copy the blades in pairs, not singlely one after the other. Ie, the blades are 100mm apart, and in a / \ pattern meaning that each instance of / or \ 'should' duplicate every 200mm. Except when I lengthen the block by 200mm it won't duplicate untill I've gone double the distance (400) when it gives me both / and \.
Does anybody know of any solutions? Or if it's possible?
Solved by ojuris. Go to Solution.
