• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Dynamic Blocks
    Distinguished Contributor
    Re: Dynamic Block Show Off TOO
    04-18-2012 06:36 AM in reply to: ChuckUK1971
    Limits... are based on UK building regs limits.
    Hm, kind of.
    Although it's ultimately up to the discretion of your Building Control Officer, generally a 220 going can be used with a max. 198 riser. Similarly, a max rise of 220 can be used with a min. 244 going.
    Please use plain text.
    ChuckUK1971
    04-18-2012 12:27 PM in reply to: strawberry12
    My statement meant maximum and minimum sizes of going and risers, that are given in Part K and Part M of the UK Building Regs, both inside a building and out.
    It is only a range, not a calculator that will avoid the need to think in the average Cad Monkey.
    12-31-2012 12:41 PM in reply to: Charles_Shade
    This callout block took me some serious help from ojuris (Distinguished Contributor) , utilizing  a different thread in this forum. Thank you, Juris!
    It is designed to work with the Sheet Set Manager, having sheetset placeholder fields. The actual block can be positioned by first stretching the arrow point to the feature being called out, then by stretching the block to a suitable place for the text, flipping it if necessary. So, it is basically a Sheet Set Manager multileader. You can also position it by inserting it where you want it in the first place, of course.
    It is set to be annotative to every scale I use, so you might have to remove some for your use.....also, of course, the units may have to be adjusted....
    I have not tested it for use with the insert block command, because it is intended for use with the sheet set manager.
    enjoy!
    Donna
    Charles_Shade
    01-02-2013 05:57 AM in reply to: elderla
    Thanks. Glad to see others looking to share and add to this (and the other share) thread in this Forum.
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    01-02-2013 06:07 AM in reply to: Charles_Shade
    Neat little block I cam up with, uses visbility to switch between 6 different type of views, allowing use of a single reference bubble for detail referencing, section referencing, elevation referencing, and detail call outs with choice of circular or rectangular.
    With the latter choices, the reference bubble and the circle/rectangle can be moved indpendently to each other, and the circle/rectangle can be resized as well, just adjust some of the other linework joining back to the reference to clean it up.
    Active Member
    02-01-2013 03:09 PM in reply to: Charles_Shade
    I just started building DBk's and don't have anything impresive to show off but I have to say the samples are so heplful to my understanding of how DBk's work.
    I am (sadly) well behind the times (LT2009) and I despise DWG Truview with a passion. I find it so painful to use and will launch it only if absolutely necessary (ie I know that there is something in the .dwg file that I really, really want).
    I know I may be asking a bit but it would be awfully nice if you could "save as". I'm pretty sure it's like a million times easier for you to do that than for me to **** around with the vile program.
    Holly
    Charles_Shade
    02-03-2013 04:24 AM in reply to: Holly_Jones
    Are you using Trueview to Convert DWG files to 2007 release format?
    If so there is no need to SaveAs. The DWG file is just "updated" to that format.
    Then Open it with LT.
    Active Member
    02-04-2013 08:28 AM in reply to: Charles_Shade
    Thanks, Charles. I guess there's something to be said about knowing how to use the tools that are available.
    Valued Mentor
    02-06-2013 10:38 PM in reply to: Holly_Jones
    Here is my humble offering, it's a work in progress, I use it for a visual check of door handing against an x-ref, and also for inputting data from site surveys as to door opening sizes, we can have several hundred doors on a project. each block also has about 250 attributes, listing various features and door furniture but most are just there to autopopulate our excel door list. I use layer naming and colouring, to group doors by types. -ATTEDIT is great for globally changing attributes in all the blocks, which is a real time saver.
    A lot of the info is in Dutch but you can see the possibilities, I am hoping to add visstates for different frame types and a more visual effect for things like fire rating and door furniture, as well as double doors.
    The title of this thread contains "Show Off" so heres the show off bit, I then have an excel sheet that manipulates the data and produces various lists for ordering door blanks and door furniture. All I need do then is prepare the faxes and place the orders, now if I can just get our IT department to install fax drivers.
    Regards Steven Gray
    Setting Out (Joinery Manufacturing)
    Autocad 2013LT
    Windows 7 professional
    Valued Mentor
    02-11-2013 11:13 PM in reply to: steven-g
    Just a couple of simple ones that I use a lot. I do a fair bit of cabinet design and these help divide up spaces, I have quite a variety of different ones based on the same idea. One is just a straight divider you can either work with set distances ie. set distance1 to 600mm and use the other points to position items every 600mm or pick the 5th point and stretch it to divide an object equally.
    The second divider I use to place 18mm shelves at equal distances within a cabinet without having to grab a calculator to work out if 4 or 5 shelfs is better. A variation of this one uses a standard 32mm hole spacing for shelving.
    Regards Steven Gray
    Autocad 2013LT
