I seem to have the same problem. But I dont understand the solution here.
Flip action doesnt seem to flip the angle offset and so stretch works in the opposite direction.
To elaborate on the question I prepared a file.
/The answer in this thread is a mystery to me.
How do you add an action to another action's selection set? I cant seem to select actions as objects.They are like, flying little icons in the block editor free from model space /
...which is the easiest solution.
If you choose not to you can Right click the Icon and then have the options to choose to add or remove items to the Selection Set. This is additional steps beyond just using a simple Double Click that setting BACTIOBARMODE to 0 will allow.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
...and No.
It's just a pain to do it that way. Basically you start over.
