• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Dynamic Blocks
    Valued Contributor
    amflasf
    Dynamic Block Help Again
    81 Views, 1 Replies
    04-11-2012 01:37 PM
    Attached is a dynamic block I use for our planting plans.
    It works great in the current set up BUT I do have to mirror it (with mirrtext set properly so text is correct orientated).
    When I fill out the information in the mirrored state the alignment is off with some of the attributes.
    What alignment do I need to get it to work so when I type in both states it's align correctly?
    Can someone help adjust?
    Thanks!
    Please use plain text.
    Distinguished Contributor
    truss_85
    Re: Dynamic Block Help Again
    04-13-2012 12:22 AM in reply to: amflasf
    It is hard to say a solution for that.
    But I have an approach to solve that.
    Ddo you really need that att to mirror?
    I mean only lines can flipped. Take look block.
    Best Regards
