• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Dynamic Blocks
    Valued Contributor
    Accepted Solution
    Door Swing Arc Does Not Scale Correctly
    163 Views, 2 Replies
    06-19-2012 10:24 AM
    The attached is a plan view of a box with a door.
    I am trying to get the door swing arc to scale correctly as the width of the box is changed.
    But the block is defying logic by scaling the arc radius exactly 5 units short of what it should be.
    I've tried deleting, recreating, and chaining the parameter over and over only to have the same problem each time.
    Can anyone help?
    Thanks!
    Pete
    Please use plain text.
    *Pro
    nestly
    Re: Door Swing Arc Does Not Scale Correctly
    06-19-2012 11:11 AM in reply to: pete592
    The block seems OK to me.  I think you may have made some changes to the block definition, but did not "reset/update" the block that's in the drawing.  (Right-click > Reset)
    Valued Contributor
    06-19-2012 11:14 AM in reply to: pete592
    Reset the block, what a concept!
    Thanks!  I figured it was something easy.
