Dynamic Blocks Forum
Distance Multiplier
5 REPLIES 5
583 Views, 5 Replies
Distance Multiplier
Does anyone know what could be possible reason for not being able to change value of distance multiplier (stretch action)?
Many thanks in advance 🙂
5 REPLIES 5
pete592
The only thing that comes to mind is that the stretch action may be associated with a chained parameter.
If you can attach the block to a post, myself or another member would be able to look at it firsthand and find out what the problem is.
Funny thing now is this.. I inserted that block into container dwg and when I open bedit from there distance multiplier is 0.5, but when I open original drawing I can't change it. Now I am really confused. Please help 🙂
p.s. since I can attach only 1 file per post I am sending original file rather then container, because it actually works when inserted into another drawing as explained
pete592
I wish I had something to offer. Sorry. 😞
Perhaps someone else does.
I've seen dynamic blocks do some pretty weird and seemingly unexplainable things, but this probably tops them all.
Pete592, thank you so much for looking into it. It helps to know that I am not missing something obvious, which is usually the case when you work on something for days. I posted this on AUGI forum, maybe someone will come up with solution. Thanks again for time you spent trying to help 🙂
MennoMekes
I checked your block out but if I open it I can change the multiplier. (both when I open the dwg in the blockeditor and when I insert it and then edit the block)
I don't know either,
Menno
”Boost
”Tips
”Services
