Hey,
I have a problem with replacing dynamic blocks from one computer to another. I can use block but i cant put into palettes block from another computer. Maybe someone knows why?
Please follow these steps on the attachment.
another option is to use design center (ctrl2) or dc on your keyboard
browse to the location of the content you seek and sort by category
se attached image
Only problem I have with design center, its a long path to follow if you go to home, or if you are in a different location and browsing to your drawings. I prefer the tool palette because it is quick to use and a bit more organized. But obviously it is personal preference
i agree
each network is set up differently, so if the resources for the tool palettes are not configured properly you will have this issue at every workstation
but Design center is a good back up plan
all tool palette containers should be network ready for better sharing
@Kidainyte: Do you still have and issue or has it been sorted out now?
