• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Dynamic Blocks
    Active Contributor
    DB Rotating text problem. Any suggestions?
    147 Views, 3 Replies
    01-14-2013 12:50 PM
    After opening the test block, use the Rotate parameter and notice the perfecting. Now use the move parameter on the circle/number and move away from the base object. Then rotate again and notice the number. The numbers action is the problem.
     I have an issue with the number rotating on a different axis when it should be within the circle at all times. The issue arises after moving the circle/number then rotating it. The circle is acting perfectly, overall, but the number is acting odd.
    Thank you in advance for any suggestions.
    -Jarred M.
    Please use plain text.
    Distinguished Contributor
    truss_85
    Re: DB Rotating text problem. Any suggestions?
    01-14-2013 11:10 PM in reply to: jarredmonday
    I think it is working. Take a look. There is no need to add 2 points, besides one of them chain action is off. Let me know if is not that you want?
    Regards
    Active Contributor
    01-15-2013 05:19 AM in reply to: truss_85
    Thank you very much, I was going around in circles on this one. Seems simple enough now. Great job thank you.
    truss_85
    01-15-2013 06:40 AM in reply to: jarredmonday
    Anytime you need. I am glad it is working.
