Dynamic Blocks Forum
Conditional Visibility Help
1 REPLY 1
Remlapw
513 Views, 1 Reply
Hi I am currently creating many dynamic blocks and I have the need for visibility states.  What I would like appear invisible in one of the two states is a polygon surrounding a text attribute.  I would like this polygon to become invisible when the text attribute inside of it has no value filled in and visible when there is a value to the attribute.  Is this possible?
I am using Autocad Electrical 2011
Will
1 REPLY 1
Moshe-A
in reply to: Remlapw
can you post a sample block here? describe how it's function?
when an attribute value is nothing (null string value) do you
know how to select it the next time you want to set it?
as far as i know there is no build-in solution to this but with VisualLisp
it can be solved.
cheers
moshe
”Boost
”Tips
”Services
