Dynamic Blocks Forum
Complex Parametric Triangle - Is this possible?
3 REPLIES 3
249 Views, 3 Replies
Has anyone attempted to create a dynamic block of a parametric triangle with
2 boundaries?
Architectural Application - Triangle louver for the gable end of a house
Requirements:
1) Control the size of the outer boundary for width (base) and height (peak)
2) Inner boundary is parallel to the outer boundary and has a fixed gap
distance; inner boundary is chained to outer boundary
3) Set up a lookup table for different roof pitches
Thinking out loud here, the only solution I can reasonably come up with is
to use points and create an elaborate table for both the outer and inner
boundaries.
Any other ideas? I am trying to avoid using visibility states and nested
blocks.
John
3 REPLIES 3
Have you thought about using an MLINE for the inner and outer boundaries?
Daniel J. Altamura, R.A.
Altamura Architectural Consulting
and SoftWorx, Autodesk Authorized Developer
http://partnerproducts.autodesk.com/popups/company.asp?rdid=2139
Hi Daniel,
Thanks! I couldn't see the trees through the forest. I keep forgetting
about Mlines. Now I have an application for them and it works!
John
; "R.A." wrote in message
news:5161966@discussion.autodesk.com...
Glad that little "nudge" helped! I must admit, I never use Mlines either.
; "AIA" wrote in message
news:5164448@discussion.autodesk.com...
Hi Daniel,
John
”Boost
”Tips
”Services
