Dynamic Blocks
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Block with field doesn't work if paste from Tool Pallet
- Highlight
- Email to a Friend
- Report Inappropriate Content
I have problem with attached block (also with other similar blocks with field). This block include field in block attribute. Works fine if I copy and paste this block. When I drag and drop from Tool Pallete field disappeary. Is it any way to fix this problem?
Chris
Re: Block with field doesn't work if paste from Tool Pallet
- Highlight
- Email to a Friend
What happens if you drag the Block from the Palette and then Explode it?
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
- Highlight
- Email to a Friend
Just exploded, like typical... I get my geometry and attributes.
- Highlight
- Email to a Friend
I wanted to make sure that it was not a nested block.
BTW - The Field stays visible when dropped from the Palette here.
- Highlight
- Email to a Friend
May be You can try make new block, when You insert Your block. That new block include in tool palette and there for that block define to explode that block, when insert from tool palette
Juris
- Highlight
- Email to a Friend
Nope. No field when drop from pallete, just value of field. I think problem is field refer to object and I don't know why when drop from pallet the new block is like a new object.... something like that...
- Highlight
- Email to a Friend
Thats the problem. A block cannot refer to itself when it is inserted. Copying works fine
Setting Out (Joinery Manufacturing)
Autocad 2013LT
Windows 7 professional
- Highlight
- Email to a Friend
Try another block
Juris
- Highlight
- Email to a Friend
works fine! thanks! what did I wrong???
- Highlight
- Email to a Friend
I create field in block editor space, not in drawing space
Juris
