Dynamic Blocks Forum
Block loose shape after flip action
3 REPLIES 3
374 Views, 3 Replies
I'm trying to make a dynamic block of a door with the following rules:
- for any door lenght
- for any wall thickness
- keep door thickness
- flip both vertical and horizontal
- rotation
Attached, some sample that I made. But it looses shape when I apply flip and rotation. It also get weird when I try to scale after a flip.
Can someone help me?
3 REPLIES 3
steven-g
Try and simplify your block a bit, you don't need Escala and Folha, the stretch and the scale actions can use the same linear parameter. Your block goes misshapen because the rotation isn't centred on some of the other parameters, you possibly could get things working, but it would be easier to start again with the parameters, and base everything on the hinge point of the block and just use one linear parameter based on door size, you can always use a formula in an attribute (using fields) to report the door opening, it doesn't need to be the driving distance. Doors tend to be standard sizes anyway, if you do need to use the opening size as your input value then start it at the hinge point and let the right hand end float in space (things will still work and it makes the logic much easier to work with).
ojuris
try this
Libbya
I'd 'polarize' it.
”Boost
”Tips
”Services
