• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Dynamic Blocks
    kuiva
    Behaviour of stretch action
    602 Views, 6 Replies
    08-14-2010 02:19 AM
    How come on some computers when i use a dynamic block with stretch action and input 1000 the length of the object becomes 1000, and on different computers the input 1000 is added to the existing lenght of the object.
    I would always prefer the first option. Is there a system variable or something to adjust the behaviour of streching dynamic blocks?
    Please use plain text.
    Charles_Shade
    Re: Behaviour of stretch action
    08-14-2010 04:58 AM in reply to: kuiva
    Same DynBlk?
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Distinguished Contributor
    08-14-2010 02:39 PM in reply to: kuiva
    Check the setting of:
    DSETTINGS
    Dynamic input tab
    Enable dimension input where possible Check Box
    kuiva
    08-15-2010 12:24 AM in reply to: sgrya1
    That did it. Thanks!
    Charles_Shade
    08-16-2010 04:51 AM in reply to: kuiva
    Good Tip.
    Thanks.
    Employee
    08-11-2011 09:54 AM in reply to: kuiva
    ACAD 2012/ 2011 SP2 there is a problem with Osnaps.  You have Tangent or Perpendicular in your default Osnaps.  Something is not right and it seems when you are stretching these two osnaps interfere. (So some computers don't have it on and some do or some have SP2 and some don't)
    The other suggestions are good and may help. But, be aware.  Work around presently is to turn those two osnaps off by default. This issue has just come to our attention.
    Dan
    Autodesk, Inc
    Employee
    03-26-2012 09:11 AM in reply to: dan908
    I can say that 2013 will have the stretching problem addressed so that the perpendicular and tangent osnaps do not interfere with the operation. This problem was presented to us after the 2012 service pack 1, but is marked to be considered for a future service pack if there is one (I am not someone who knows this).
