Hello all,
I've made a dynamic bloc which combines actions and visibility states. I can stretch the block as needed but once I change the visibility the element that was stretched was reset but others didn't. To remedy this I used the ATTSYNC command and everything was good!
My questions is the following;
- Is there a setting or code that can make the ATTSYNC command automatically execute everytime I change the visibility state?
Bryan
Only if you change the Macro that Saves the DynBlk in the BE.
KISS method works best. Run ATTSYNC
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
