Sure wish you could manipulate the Column Offset of an Array Action with a Stretch Action.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I second this. I'm trying to build a block that needs this also. Wish you could add paramaters into the column value. Seems like this would have been done by now.
I guess this is remedied by visual states for now... Shame.
I also wish it would array the attributes associated with the array components...
I am trying to do rebar spacing but can't, any ideas?
Just a simple circle, and with different spacings.
The attached example draws rebars with 15cm spacing, but what about varying distances, ie 15, 23, 8.....?
Can't a normal array action be used?(outside of a block)
The array command has changed in 2012 release. I'm using 2011, so my data is not quite up to date.
I wish you could use fields in formulas within the properties just in general... That would give UNLIMITED POWER!
Kind regards
Windows 7 - AutoCAD 2012, SP2
As of 2015 there is still no way to dynamically adjust the column spacing of an array. If you have a short list of specific offsets, you can create individual visibility states for each and switch between them.
RE your block, if you are going to use dynamic parameters/actions you should get rid of all the constraints. They usually don't play well together.
