Dynamic Blocks
Active Contributor
bcasper
Message 1 of 5 (277 Views)
Annotative Blocks
277 Views, 4 Replies
08-17-2012 12:13 PM
Good afternoon everyone,
I've just started to learn how to use Annotative Blocks and i'm running into what is probably a very simple problem.  I'm creating a block and want to assign annotative scales to it.  Once created, I insert the block into the drawing I need to use it in, and the only scale that shows up is the scale that is active when inserted.  All the other scales I added when creating the block are gone and I then have to assign the scales to the block again.  What am I doing wrong?  Or is this the way they are?  I would prefer not to have to manually assign the scales everytime the block in inserted into a drawing.  Any help you could give would be greatly appreciated!  Thanks.
Brian
Valued Mentor
AcadAdamLT
Message 2 of 5 (262 Views)
Re: Annotative Blocks
08-20-2012 03:06 AM in reply to: bcasper
If I remember it right (been some time since last annovative block) you have to have the annovative block saved as a drawing file, and in that drawing file all the scales needs to be set. Then when you insert the block the scales will follow.
You can use the "save block definition to drawing file" checkbox to save it as a new drawing file.
Hopefully I remembered it correctly.
Good luck to you.
Signature, sincerely... //Adam
AutoCad LT 2014
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
Active Contributor
bcasper
Message 3 of 5 (219 Views)
09-17-2012 11:52 AM in reply to: AcadAdamLT
I tried this but it didn't work.  The block is saved as a drawing file and the scales needed are inserted into the file, but the scales still don't stay added to the block.
Valued Mentor
steven-g
Message 4 of 5 (212 Views)
09-17-2012 11:01 PM in reply to: bcasper
Works here, could you post one of your blocks someone will take a look.
Regards Steven Gray
Setting Out (Joinery Manufacturing)
Autocad 2013LT
Windows 7 professional
Valued Mentor
AcadAdamLT
Message 5 of 5 (199 Views)
09-19-2012 12:11 AM in reply to: bcasper
What version are you working in?
AutoCad LT 2014
You are not logged in.
Ask the Community
