• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Dynamic Blocks
    Annotative Blocks
    217 Views, 4 Replies
    08-17-2012 12:13 PM
    Good afternoon everyone,
    I've just started to learn how to use Annotative Blocks and i'm running into what is probably a very simple problem.  I'm creating a block and want to assign annotative scales to it.  Once created, I insert the block into the drawing I need to use it in, and the only scale that shows up is the scale that is active when inserted.  All the other scales I added when creating the block are gone and I then have to assign the scales to the block again.  What am I doing wrong?  Or is this the way they are?  I would prefer not to have to manually assign the scales everytime the block in inserted into a drawing.  Any help you could give would be greatly appreciated!  Thanks.
    Brian
    Please use plain text.
    Valued Mentor
    AcadAdamLT
    Re: Annotative Blocks
    08-20-2012 03:06 AM in reply to: bcasper
    If I remember it right (been some time since last annovative block) you have to have the annovative block saved as a drawing file, and in that drawing file all the scales needs to be set. Then when you insert the block the scales will follow.
    You can use the "save block definition to drawing file" checkbox to save it as a new drawing file.
    Hopefully I remembered it correctly.
    Good luck to you.
    Signature, sincerely... //Adam
    AutoCad LT 2014
    09-17-2012 11:52 AM in reply to: AcadAdamLT
    I tried this but it didn't work.  The block is saved as a drawing file and the scales needed are inserted into the file, but the scales still don't stay added to the block.
    Valued Mentor
    09-17-2012 11:01 PM in reply to: bcasper
    Works here, could you post one of your blocks someone will take a look.
    Regards Steven Gray
    Setting Out (Joinery Manufacturing)
    Autocad 2013LT
    Windows 7 professional
    Valued Mentor
    AcadAdamLT
    09-19-2012 12:11 AM in reply to: bcasper
    What version are you working in?
    AutoCad LT 2014
