I have a block that when I extend it, a new 10' section is added. It will only add the 10' piece (array). What I am looking to do is find a way so that once I hit a total distance have it switch the part that it adds. So I have like a rail, I keep adding these 10' pieces and then once it hits 40' I want it to add the end piece which is different.
If anyone has any insight please let me know.
Thank You!
Welcome to the Autodesk Forums!
Check out the attached drawings in posts 11 and 16 of this Thread:
http://forums.autodesk.com/t5/Dynamic-Blocks/Stretch-amp-Array-dynamic-block/m-p/4575533#U4575533
This is similar to what it sounds like you are asking to do.
Always attach your DynBlk attempt when asking for help. That way we can see what you have.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
