Dynamic Blocks
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
19" cabinet Numbering up or down
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
hi,
I have made a dynamic block, but I do not find a way to get a counter in my bloc.
see the example , it must go from 01 -> 15 if the chose was 15HE,
can someone help me?
Re: 19" cabinet Numbering up or down
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think the only way you will be able to get this done is by changing your use of the visibility states, so that the numbers show up as the length increases. you should be able to add the different visibility states into the table that controls the sizes. Just use a zero length to make the sokel not show up, and that frees up the visibility action to place your numbers.
Setting Out (Joinery Manufacturing)
Autocad 2013LT
Windows 7 professional
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've made a block whit the numbering for a cabinet 800 and one for a cabinet 600.
Also the block for the plinth.
Works fine.
Now I would like to merge those three blocks.
The problem is the cabelhoops for the cabinet 800 and the screws in the plinth.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It will need tidying up a bit, ie. label names and such, and testing but hopefully it should do the trick. The hard bit is the screws, adding those onto the visibility state would have made a very long list, scaling them seams to have worked but they did a lot of moving about, before the combination of actions worked, and not sure if it will be ok for all the size variations.
Autocad 2013LT
