Drafting Techniques
Member
opti432
Message 1 of 8 (358 Views)
"Stretch" a line into a curve
358 Views, 7 Replies
12-29-2012 01:57 AM
I am using a plugin on Autocad called Sofiplus. It allows me to do Finite Elements analysis based on a drawing on Autocad. The problem is, i have to create a curved element and the plugin only makes straigt lines, even though I know it can work on curves. Is it possible to create a straight line and then "curve" it? Most drawing programs do that, even paint I think.
Thank you and I hope I was clear enough.
pendean
Message 2 of 8 (349 Views)
Re: "Stretch" a line into a curve
12-29-2012 12:15 PM in reply to: opti432
Your AutoCAD version?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
opti432
Message 3 of 8 (346 Views)
12-29-2012 01:21 PM in reply to: opti432
2012 (Education)
pendean
Message 4 of 8 (328 Views)
12-31-2012 12:45 PM in reply to: opti432
draw a line.
select the line.
hover your mouse over the center grip: a menu pops up, one of the choices is to convert to an arc.select it.
experiment.
Charles_Shade
Message 5 of 8 (310 Views)
01-02-2013 06:02 AM in reply to: pendean
Draw a PLINE and hover over the center Grip bar to convert to arc.
The center Grip on a LINE is dumb and not a Multi-function Grip.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Member
opti432
Message 6 of 8 (287 Views)
01-03-2013 01:46 PM in reply to: opti432
so there is no way to do it on a LINE? maybe in another autocad version (a previous one)?
Charles_Shade
Message 7 of 8 (280 Views)
01-03-2013 05:48 PM in reply to: opti432
If you do this to the line in your version of CAD is it possible?
If not then I believe you have your answer.
Though if you do such with the PLINE and then EXPLODE it you will have an Arc or curved Line.
stevor
Message 8 of 8 (245 Views)
01-09-2013 04:12 AM in reply to: opti432
If Sofiplus can process 'curves' then ask Sofiplus how to do so.
If not, you can reform the curve into many short lines, and use them.
An autolisp solution would be the easiest to make:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
But you can do it manually if you have the time.
S
You are not logged in.
Ask the Community
