I made a 3D model in Autocad2013 and on the lay-out I made a viewbase and viewsections. Everything went well but after a while I had to change something and the command ‘update view’ don’t work anymore. So I tried the commands viewbase, viewsection,… none of them act normal. By viewsection I can select a view but 1 found, 1 filtered.
I tried another old drawing and everthing went well.
I even restart my PC. No result.
How can I solve this problem?
I nothing else, you could try starting a new drawing, then copybase model and viewports into it one by one to see if it works, or when it breaks etc...
My model is still ok
I can copy it to a new drawing, but then start the job to make the drawing nice, change hatch, dimensions, levels, groundlevel, exra text, .... a lot of work. And I will loose all of this.
I don't use viewports anymore.
I have to present a 2D of my 3D so I use viewbase, viewsection,...
I have had the same problem, sometimes the views go berserk!
Sometimes they will restore after a shut down and restart.
It seems once the view is broken they need to be redone?
