Drafting Techniques
j.vanderheijden
Message 1 of 6 (215 Views)
Accepted Solution
making Hatch
215 Views, 5 Replies
09-12-2011 01:26 PM
Can or will anybody help me with making a hatch.
See attachment.
Mvg Jos
Your drawings are only as good as the symbols that complete them...
*Expert Elite*
azrdgldr
Message 2 of 6 (211 Views)
Re: making Hatch
09-12-2011 02:58 PM in reply to: j.vanderheijden
Research the help files, this is simple.  Make circle start the hatch command, select the hatch style prefered and then select the objects, in this case the circle and you should have hatch.
*Expert Elite*
Charles_Shade
Message 3 of 6 (196 Views)
Re: making Hatch
09-13-2011 10:14 AM in reply to: j.vanderheijden
Will this work for you?
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
j.vanderheijden
Message 4 of 6 (185 Views)
Re: making Hatch
09-13-2011 01:08 PM in reply to: Charles_Shade
Thank you Charles
This looks good.
Have a small problem, if you zoom in you see that the lines do not exactly fit.
Is it possible to adapt the code?
Perhaps with an explanation.
so i can do it my self?
Mvg Jos
*Expert Elite*
Charles_Shade
Message 5 of 6 (173 Views)
Re: making Hatch
09-13-2011 04:52 PM in reply to: j.vanderheijden
The entities of the hatch are what I copied from your drawing. I'll take a look and make sure each are "joined" together.
I see what you are saying but I can only guess that it is a limitation in the program. Not sure how to fix that.
This was made using a program named Hatchkit. I've had it for several years and have used it extensively and would not be without it.
*Expert Elite*
azrdgldr
Message 6 of 6 (169 Views)
Re: making Hatch
09-13-2011 05:30 PM in reply to: j.vanderheijden
By your terminology I thought you wanted to create a hatch and not a hatch pattern.  Two different things.  Look into the customization portion of the help files to show you how to create a custom hatch pattern as you desire.
You are not logged in.
Announcements
Need installation help?
Ask the Community
