• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Drafting Techniques
    bgerold
    Accepted Solution
    edit hatch of xref
    229 Views, 5 Replies
    09-26-2011 02:24 AM
    I'm new here.
    I'm looking for a smart solution to edit hatches of xrefs.
    So this is what I want to do: while my colleagues are working on some plans, I need to print out a set of these plans with all hatches solid black. It' s not possible for me to go in the originals files to change the hatches. I have a file set up for print with all the plans placed as xrefs (layout in paperspace). Is there any way to edit these hatches without binding the xref? We're using autocad 2012 for mac and all quite new to autocad, help is very much appreciated.
    Thank you for your help.
    christian
    Please use plain text.
    *Expert Elite*
    Charles_Shade
    Re: edit hatch of xref
    09-26-2011 05:52 AM in reply to: bgerold
    Its not possible to open and print a file that is open on another system regardless; Correct?
    Printing the Hatches solid black may be a Style Dependent plot options perhaps?
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    *Expert Elite*
    JGerth
    09-26-2011 08:01 AM in reply to: bgerold
    use Express Tools to Copy Nested Objects, and use 0,0 as both base point and destination point.  Then just edit the copied hatches to use the Solid pattern.
    delete when no longer needed.
    bgerold
    09-26-2011 10:00 AM in reply to: JGerth
    Thanks for the replies,
    copy nested object seam exaclty what I'm looking for but as far as I could find out ncopy doesn't exist in autocad for mac....
    maybe there's a way to edit haches through the plot style settings? I'll have to look into that.
    bgerold
    09-28-2011 01:24 AM in reply to: bgerold
    So far no luck with the plot style settings changing all hatch to solid black. The fill style options applies only to solids, splines and 3-d faces.
    bgerold
    09-28-2011 01:58 AM in reply to: bgerold
    solved! changing all hatch types in the original drawing to background color 255 (white) and then set that color in the my plot styles to print as black. Thanks very much for your help!
