I need to draw a concentric spiral in Autocad 2014 to develop a fanhousing similar to the one in attachment.
Does anybody have any tips in how to do this.
I have tried to join tan tan tan circles, but the curve isn't smooth.
I have tried spiral, but this is centric.
Thx
Kelly
Solved by Kent1Cooper. Go to Solution.
Does anybody have any tips in how to do this.....
You may be able to use one of the commands in the attached that I did a few years ago. It's not quite clear to me from your photo whether the equal or arithmetic or geometric spiral would be best, but try them out. Use a large number of segments per turn for a smoother result.
Hey,
Thanx for your reply. Unfortunately it didn't help me with my drawing.
I tried all your commands but I ended up just connecting arcs.
I had to recreate that exact object, and had to measure it up completely...
I didn't give up en ended up with a great result!
greetz
Kelly
Helix or Spiral should work, specify two different radii, specify number of turns as .75, or what ever works for you.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
