I have used the circle tangent tangent radius command tons in the past with no issues. for the last few versions it no longer works as it used to. it used to work as follows: draw two lines, create a circle TTR, start trim command, select all three entities, trim the circle at the two lines and the lines at the remaining arch to end up with a line a tangent arch and another tangent line segment witch could them be turned into a poly line as all the end points were correctly lined up. try it for yourselves, the lines and circle no longer trim as if they are not actualy intersecting. so what is it they actually are not because the TTR no longer works or is the trim command not working??
All versions (2011 thru 2014) still work fine here. The only thing that comes to mind at the moment is the EDGEMODE variable, or perhaps a UCS out of plane issue.
Can you post a sample drawing with two lines and a circle that have been trimmed against each other.
Sometimes happens when I'm working on objects very far from the origin (0,0,0), in these cases I use the command "fillet" with the option "radius", instead of the "circle" and then "trim"...
Henrique
You may have something with the objects being far from 0,0. However, it never used to be a problem. I often worked in drawings with huge coordinates working with survey drawings, so changing the 0,0 closer to objects isn't an option. does changing the limits maybe, or any thing else have any influence? Attached is a sample dwg. the middle large diameter circle trims fine the other two not so much. all created with the circle TTR command.
I've gotten so used to the unreliability of trimming circles created with TTR, or trimmng _to_ the circles, that it just seems normal. Most of my work is in State Plane, with coordinate value in the million/tens of millions, so I've always shrugged it off as rounding errors. I've used numerouse workarounds, either trying to BReak at an intersection, or dawing a line from center to perp on the other object.
It would be nice if the thing worked as expected though...
I confess to wondering why you would draw Lines and a Circle in TTR fashion and then trim them into exactly the configuration that results from using the Fillet command instead. Fillet is much less work, and never fails in the way you describe, in my experience -- is there some reason not to use it?
You're probably right with regards to TTR, but the same situation arises when the arc/cirle is the existing object and a line is snapped tangent.
I'm glad I don't need to do work 80 million units from the origin.
nestly2 get it. Its not only circle ttr, drawing lines tangent doesnt trim either. And its awful hard to draw a line to an intersection that should exist yet isnt recognized, trying to create some construction lines as a work around for a simple command. My workmate came to me yesterday saying his autocad was acting up, he had drawn a line from an intersection of tw other lines then went to trim one of them and it would trim the line by selecting one of the lines but not the other. both lines met at the same point yet only one line would trim. and not at some crazy coordinate. something is up with trimming.
@Kent1Cooper wrote:I confess to wondering why you would draw Lines and a Circle in TTR fashion and then trim them into exactly the configuration that results from using the Fillet command instead. Fillet is much less work, and never fails in the way you describe, in my experience -- is there some reason not to use it?
Well, one reason is that fillet doesn't work between plines and arcs, another is that I may not want to break one of the objects -- say connecting a conc sidewalk with a boardwalk. I want a smooth transition, but certainy don't want them to become the same object.
Typically I would use the FILLET command with the Trim option turned off for this. At least that way you don't have to trim the circle. But presumably you will want to trim one of the lines, and you will discover the same old problem persists here too; no trim point will be found most of the time.
(Most of my work is about 5,000,000 m from the origin.)
Mark Green
Working on Civil 3D in Canada
