Autocad slow / crashing. Noticed that certain lines in a complex masterplan drawing seem to trigger the program going slow / after half an hour requiring a forced shut down ... because nothing is happening after 20 minutes & more of waiting. but leving it over an hour for lunch sometimes has the "thinking" resolved withe the computer waiting for the next command.
The lines in question seem to have a flying blue flag. I have used the parametrics tray & used the appropriate flag x on a selected problem line ... sometimes it works ... sometimes the dwg goes into a thinking mode that never resolves, forcing a shut down.
the drawings also seem to assume huge file sized. I have tried to reduce the size by having only a few small dwgs in a folder at a time ... but the size still appears big ... out of proportion to what is drawn in the file. Purging & auditing is being done. On a few occasions auditing a dwg has made it go into a long "thinking" mode ... ultimately requiring a forced shut down via the task manager
HELP someone 🙂
The Blue Flag is an indication that Constraints have been used.
Someone may have AUTOCONSTAINed entities in the Drawing file if you are unaware of these.
DELCONSTRAINT can be used to remove the Constraints if need be.
Does this file have many Dymanic or Parametric Blocks in it?
Lots of Hatching perhaps?
How about some computer and system specs as weel as your Version of CAD too please.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
How big of a file are you talking here? Any XREFS? If you have google chrome installed on your computer I suggest uninstalling it, for some reason it makes Autocad and other design software go haywire.
Mark Green
Working on Civil 3D in Canada
Im not savvy with programming and such, but the IT guy at my school told me that was why my CAD and Revit always crashed... not sure what it is about it. But now that im in an office I uninstalled it from my work comp and run CAD and Bentley Inroads without many problems. I suggested it to all the other engineers and cad techs and they have all seen an improvement aswell. Ive also found that only having having 1 sheet layout per file makes a dramatic difference when it comes to crashing and issues. We just use master files for our design work and then xref the master file into each sheet file and freeze/unfreeze what we need per sheet. If you xref jpegs or large files always unload them before saving and closing and your program and file will open and run smoother aswell. There are lots of tricks to operate Cad with minor crashing incidents, most of which is just learning through experience. Most people click too much with thier mouse, and that will also cause problems. Having more than 2 or 3 cad windows open, having large areas/many areas with hatching, etc. Hope some of these help if you didnt already know about them.
OP have you tried (as a separate test) writing the entire drawing off as a block?
I would say your probably right. Xrefs have thier ups and downs, what i like about them though is the ability to unload them until needed and easier placement into the coordinate system. Im in the trasportation group at CH2M hill so we use master files for existing-site, proposed-site, topo, and titleblock... once xrefed in you have the ability to turn layers on and off... "NCOPY", "XLIST etc. It may be old fashioned but thats the way we do it company wide in the transportation group, atleast to my knowledge. We are also still running autocad 2011 which kind of sucks as 2012/2013 had a few great commands added such as PathArray among others. A 16mb file is rather large, and i suspect it is because of the amount of info it takes to store a block Yes they are useful in lots of situations, but if your working with mulitple files from the same master file it is easier and takes up alot less time to run as an xref, you then have the ability to change linetype, color, plot style, annotations, etc per sheet... without changing the master itself. Sure you end up with alot of layers and some people dont know how to use them very well... but trust me. When doing civil work they make things very easy. MEP on the other hand i would love to use blocks... you can detail each block with product name, serial number, size, cost,etc... and run quantities and such off of them which is great. Just depends on the work your doing i suppose, and we all know autocad, there are many ways to get to the same solution.... some are just more indepth than others and prone to crashing.
I always do the "Select object" option when hatching aswell because it picks out the boundary easier and you dont have to wait for the program to think about what its hatching... Turn hatching layers off when working in model space and on in viewport for plotting, it will make your program run smoother...
