Drafting Techniques
Distinguished Contributor
lorier
Message 1 of 5 (119 Views)
Viewport Plot Styles
119 Views, 4 Replies
08-28-2004 05:04 PM
Is there a way to apply one plot style to a viewport and another plot style to another viewport in paperspace?
What I want to do is have two viewports on the same layout, one viewport set to plot normally and another viewport set to plot faded. Is this possible?
*Dean Saadallah
Message 2 of 5 (119 Views)
Re: Viewport Plot Styles
08-28-2004 07:34 PM in reply to: lorier
No. See your other post for ideas. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Valued Contributor
Maverick91
Message 3 of 5 (119 Views)
08-30-2004 12:09 PM in reply to: lorier
You'll probably have to set different text styles and possibly different layers.
Doug Draper
Lea+Elliott, Inc.
www.leaelliott.com
*jonesr
Message 4 of 5 (119 Views)
08-30-2004 07:27 PM in reply to: lorier
If you are in a "sheet" file and the model contains xrefs only, you can use the old trick of renaming the xrefs and attaching them again.You then have the same info in the drawing twice with unique layer names. Use LAYER to adjust (Screen) one set of layers and VPLAYER to control the visibility in each viewport. Cumbersome but it works. "Maverick91" wrote in message news:16259605.1093893009984.JavaMail.jive@jiveforum1.autodesk.com... > You'll probably have to set different text styles and possibly different layers. > > Doug Draper > Lea+Elliott, Inc. > www.leaelliott.com
*Gordon Price
Message 5 of 5 (119 Views)
08-31-2004 08:56 AM in reply to: lorier
"jonesr" wrote in message news:4133e256$1_2@newsprd01... > If you are in a "sheet" file and the model contains xrefs only, you can > use > the old trick of renaming the xrefs and attaching them again.You then have > the same info in the drawing twice with unique layer names. Use LAYER to > adjust (Screen) one set of layers and VPLAYER to control the visibility in > each viewport. Cumbersome but it works. If you are going the two xref route, you can also put them side by side, and freeze your layers in MS. Then you can jump back and forth easier. If you do annotation and dimensioning in MS this is a big help. If you have adopted PS annotation it is unnecessary. Another benifit of doing it this way is you can create LayerStates that apply to Xrefs, so setting up say a floor plan and ceiling plan is real quick. As far as I know, you would have to do it manually if freezing layers in PS. Best, Gordon
You are not logged in.
Announcements
Need installation help?
Ask the Community
