Drafting Techniques
Active Member
russigc
Message 1 of 10 (834 Views)
Tangent between two arcs.
834 Views, 9 Replies
04-20-2009 07:33 AM
Does anyone know a quick and easy way of drawing a tangent between two arcs in AutoCAD 2009? I have attached an image showing with yellow lines where the tangent should be drawn.
Thanks so much!
Cornelia
*Gordon Stephens
Message 2 of 10 (834 Views)
Re: Tangent between two arcs.
04-20-2009 07:51 AM in reply to: russigc
What is wrong with LINE Tan, pick one arc, Tan, pick second arc? Or you
could simply set the Tan osnap and start the Line command followed by two picks
on the two arcs.
Gordon
Does
tangent should be drawn. Thanks so much! Cornelia
Active Member
russigc
Message 3 of 10 (834 Views)
04-20-2009 07:59 AM in reply to: russigc
Unfortunately when using the line or pline command you can't pick tangent as Ofang for the first point of the line... I already tried that.
Active Member
russigc
Message 4 of 10 (834 Views)
04-20-2009 08:02 AM in reply to: russigc
Never mind - it worked! I have no idea why it did not work before!
Thanks so much!
Active Member
russigc
Message 5 of 10 (834 Views)
04-20-2009 08:04 AM in reply to: russigc
I never tried the line command for drawing the tangent. I always used the pline command and that would not work....
*Gordon Stephens
Message 6 of 10 (834 Views)
04-20-2009 10:51 AM in reply to: russigc
Glad you got it sorted
Gordon
I
Distinguished Contributor
KobusE
Message 7 of 10 (834 Views)
05-16-2009 01:07 AM in reply to: russigc
Line command (not pline)
Hold shift, click on tan
Click on arc close to where tan should be
Still holding shift, click on tan again
Click on next arc close to where tan should be
Tadaaaaa!
Hope it helps.
Valued Contributor
tom_kelly
Message 8 of 10 (834 Views)
05-24-2009 11:08 PM in reply to: russigc
Earlier method also works. But what I follow is something different. I draw Circle using Circle--TTR (tangent tangent radius) - click on two arcs one after the other -- you get circle automatically drawn as tangent to other arcs. -- Take point of intersection on both arcs and draw straight line. This should be tangent to arcs.
The reason being I follow this method is you don't have to search for tangent points ..
Tom
www.indovance.com
*Craig P. Black
Message 9 of 10 (834 Views)
10-11-2009 08:14 PM in reply to: russigc
That is not going to work... what radius would you use?
So self-absorbed and egotistical, it's like those
hip musicians with their complicated shoes!
wrote in message news:6189102@discussion.autodesk.com...
tangent points ..
Tom
www.indovance.com
New Member
HeadstrongFarm
Message 10 of 10 (834 Views)
10-19-2009 08:40 PM in reply to: russigc
I have to agree with Craig. Drawing a TTR circle will *not* yield the same [correct] tangent points as a straight line unless the radius you choose is infinite. I guess you could substitute in an parsec or something for the radius and it would be close enough, but simply changing your OSNAP or using shift-click>tangent is the method that would give the correct points. It also has the added bonus of just being faster...as long as you're well used to using shift-click to pick points that you don't have set for OSNAP or you need to pick one or two points and don't want to have to turn OSNAP on and off.
You are not logged in.
Announcements
Need installation help?
Ask the Community
