Drafting Techniques
Active Contributor
jkwilliams
Message 1 of 8 (439 Views)
Accepted Solution
Inserting "MText" Parallel to a Line
439 Views, 7 Replies
09-22-2011 05:52 PM
I need a very simple way of inserting Text Parallel to a Line, but simply selecting an existing line to set the "Angle" of the Text
Can any one assist here?
Jim Williams
*Expert Elite*
Message 2 of 8 (435 Views)
Re: Inserting "MText" Parallel to a Line
09-22-2011 08:17 PM in reply to: jkwilliams
Several options to choose from.
1. Type your mtext in.  Start rotate, select mtext object, for base point select one endpoint of line and then the other.
2.  Type UCS at the command prompt and hit enter, then type in OB - hit enter, select the line you want the mtext to be parallel to.  After the icon adjusts type in PLAN and type in your mtext. When done, type in UCS, hit enter, type W, hit enter and type PLAN and hit enter and your back where you started
3. Search the lisp forum to see if someone wrote a program to rotate Mtext, or post a request there to see if someone their could write one for you.
Active Contributor
jkwilliams
Message 3 of 8 (430 Views)
09-22-2011 09:10 PM in reply to: azrdgldr
Thnaks for those options.
The LIsp option looks the best to me.
I'll investigate that path.
Many thanks for the suggestion.
*Expert Elite*
Message 4 of 8 (416 Views)
09-23-2011 08:25 AM in reply to: jkwilliams
Sorry forgot to add. There is a rotation option while creating mtext.  You can use the endponts of the linetype as reference.  I assumed your mtext objects were all ready created.
Active Contributor
jkwilliams
Message 5 of 8 (404 Views)
09-25-2011 03:49 PM in reply to: jkwilliams
Thanks for that suggestion, I will investigate that one as well.
Best Regards, Jim
*Expert Elite*
Message 6 of 8 (370 Views)
10-18-2011 07:36 AM in reply to: jkwilliams
Have you tried the TORIENT command?
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Contributor
jkwilliams
Message 7 of 8 (354 Views)
10-18-2011 01:55 PM in reply to: jkwilliams
Thanks for the tip on the "torient" command, that will be useful for both text and blosks also.
Jim
Valued Contributor
jhjirak
Message 8 of 8 (217 Views)
07-16-2012 01:05 PM in reply to: jkwilliams
there are lisp routines that not only set the text to the same angle has the line, but the set the spacing between the text and the line.  That way your drawings look cleaner.  Lisp is the way to go.  Search Lee Mac in google.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
