AutoCAD Forum
How to get a raster graphic exploded somehow?!
6 REPLIES 6
Macia.Lopez
1049 Views, 6 Replies
Hi all,
I need the following picture as to be a drawn entity in my drawing i.e. a block. I already know that there is no way rather than using attach clip and try to draw over it. Can anyone help me with this particular case?
Regards
Vest
Tags (1)
6 REPLIES 6
pendean
in reply to: Macia.Lopez
You want somebody to trace over it for you??
Go buy a type of software called Raster To Vector, there are many out there, try them before you buy one.
Or start tracing 🙂
jggerth1
in reply to: pendean
IIRC WinTopo was a freebie that could do simple things like that fairly well.
If you've got access to Corel or Illustrator, that should give you easy path tracing tools and export to dxf at least.
 Ouit of curiosity - what's the original source for that sign?
steve216586
Contact Seton in Australia. They may have an Autocad drawing they can send you for a drawing.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
jwjones1
If it's a vector PDF you can usually get the linework back out using Inkscape (free software).  I just downloaded a PDF from seton.net that had a variety of signs on it, opened the PDF in Inkscape, and then saved the results as an AutoCAD R13 DXF.  It works though it's not always the prettiest thing (text is exploded, lots of splines).
Hope that helps!
jwjones1
in reply to: steve216586
Thanks Steve 😃
rendarin
Not exactly what you're looking for, but I believe you can also open the image file up in Paint, copy it from within Paint, then Paste to CAD. It creates an OLE rather than an IMAGE. Makes it so you don't need to carry the image file wherever you send the DWG file.
”Boost
