• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Drafting Techniques
    New Member
    jineeshkumarmp
    How to change the base point of a block?
    2571 Views, 8 Replies
    07-31-2011 05:35 AM
    I wish someone will help me. I have around 10 blocks in a file in different places. How to change the base of that block with out moving the blocks? Is there any solution?
    Please use plain text.
    *Expert Elite*
    Charles_Shade
    Re: How to change the base point of a block?
    07-31-2011 09:12 AM in reply to: jineeshkumarmp
    Are these ten different block or the same block ten times?
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    *Pro
    nestly
    08-01-2011 01:37 AM in reply to: jineeshkumarmp
    Valued Contributor
    08-02-2011 09:31 PM in reply to: jineeshkumarmp
    I "bedit" the block.  When I'm in the block editor I pick up all of the objects selecting the desired base point and move that to 0,0.  There are other ways too but this is the most simple way to do it for relatively simple blocks.  Wendy
    Distinguished Contributor
    08-05-2011 03:03 PM in reply to: jineeshkumarmp
    BASE command?
    (all your BASE are belong to us)
    ______________________________
    ~ "if this were /. this would be funny"
    Valued Contributor
    02-21-2012 01:34 PM in reply to: jineeshkumarmp
    Doubleclick on your block (BEDIT) to edit block. move linework to adjust base point. Then BCLOSE. Done.
    rOSE
    *Expert Elite*
    Charles_Shade
    02-21-2012 01:39 PM in reply to: Rosebm
    And bring all the Parameters with this as well?
    And does the OP want the position of all the Blocks to change?
    Or just one or several?
    *Expert Elite*
    Bob_Zurunkle
    02-24-2012 09:33 AM in reply to: Charles_Shade
    Could OP leave base of block as is and add a grip by adding a point-move?
    If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
    *Expert Elite*
    Charles_Shade
    02-24-2012 09:50 AM in reply to: Bob_Zurunkle
    Not sure, OP has not responded to any suggestion nor offered more detailed info.
