Drafting Techniques
New Member
Message 1 of 10 (13,332 Views)
How can you measure angles?
13332 Views, 9 Replies
09-01-2003 01:21 AM
I just got autocad 2000 and I just want to
draw simple things like a triangle and be
able to see the angles. It shows me only
0, 90,180,270 degree angles. How can
measure the angles? I am new to autocad. Is
there anyway or any where to show step by
step how to do it? Any help will be
appreciated.
*Engle, Walt
Message 2 of 10 (13,332 Views)
Re: How can you measure angles?
09-01-2003 01:48 AM in reply to: noslig199
There are several books on using Autocad (search the Internet), but your
best bet is to attend a class in Beginning Autocad at a community
college. There is a huge amount of information they can teach you in
using CAD.
*Engle, Walt
Message 3 of 10 (13,332 Views)
Re:
09-01-2003 02:32 AM in reply to: noslig199
It was not my intention to be rude, but to teach a person how to make
triangles, rectangles, circles, etc., requires more than a short message.
You have to be aware of absolute and relative coordinate systems, the use of
orthogonal drawing and many, many other items.
*Talsky
Message 4 of 10 (13,332 Views)
09-01-2003 12:52 PM in reply to: noslig199
As Walt pointed out in his reply, you are simply asking too much for this
newsgroup to answer in one message. Your question indicates a serious need
for a lot of information in addition to just how to draw an angle.
I would suggest that you call your reseller and find out when they will have
the next class in a beginning AutoCAD class. The advantage of this over a
community college class is that the reseller class will be about 3 days and
about $800, and the community college class will be about 11 weeks and
considerably less in cost.
It won't matter much to you if you have to take a class in AutoCAD 2004 or
2002, because the basic fundamentals you need are essentially the same in
all versions of AutoCAD.
Also, there are many books available for under $50.00 that will enable you
to draw in AutoCAD.
My own preference is George Omura's Mastering AutoCAD 2000, but any of them
will be helpful.
Jack Talsky
"noslig199" wrote in message
news:f186204.-1@WebX.maYIadrTaRb...
> appreciated.
*Irvin, Wes
Message 5 of 10 (13,332 Views)
09-01-2003 06:27 PM in reply to: noslig199
Might be cheaper to buy a calculator and learn how to use that. Autocad is
one of the bigger calculators you can get to just work out angles. My
daughter at school doesn't need autocad to work out all different angles for
different shapes. Excel could do it with a little programming.
Distinguished Contributor
Message 6 of 10 (13,332 Views)
09-01-2003 10:46 PM in reply to: noslig199
DIMANGLULAR
*Kozina, David
Message 7 of 10 (13,332 Views)
Re:
09-03-2003 05:17 AM in reply to: noslig199
Ray Bradbury's favorite word...
Ululation
:smileyhappy:
"OLD-CADaver" wrote in message
news:f186204.4@WebX.maYIadrTaRb...
> DIMANGLULAR
Message 8 of 10 (13,332 Views)
Re:
09-03-2003 05:54 AM in reply to: noslig199
If I could spell, they'd have to pay me more.
*E, Ron
Message 9 of 10 (13,332 Views)
09-04-2003 03:40 AM in reply to: noslig199
type dimangular, hit return and then pick both lines.
You can also pick lines and type 'ls' and hit enter to see their angle in
the x-y plane, but you'd need to use a calculator to find the angle between
lines.
If it is not precise enough, go to format/units in the menu and specify a
precision, or change the precision in your dimstyle if you are using
dimangular.
appreciated.
Valued Contributor
Message 10 of 10 (13,332 Views)
09-09-2003 11:39 PM in reply to: noslig199
Why don't you try going through some of the tutorials. They might be helpful to you. They are exhaustive but useful non-the less to the amature.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
