• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Drafting Techniques
    Active Contributor
    JLeeSaxon
    Dimensioning with curves and fillets
    314 Views, 3 Replies
    10-18-2012 11:00 AM
    This is a drafting, not AutoCAD-specific, question. Hope that's allowed.
    All of my technical drawing books deal with dimensioning cylinders and rectangular prisms and leave anyone who needs to use an arc or fillet a non-right angle out in the cold.
    I've attached an example of a part I'm not sure how to dimension.
    The figure on the left, without fillets, is simple.
    The figure on the right, with fillets added, becomes a MESS. Obviously, the way I've dimensioned it in this sketch is wrong. What's the right way?
    Lee Saxon
    ELLIS
    Please use plain text.
    Valued Mentor
    Re: Dimensioning with curves and fillets
    10-18-2012 01:11 PM in reply to: JLeeSaxon
    The right way is to convey all the neccesary dims to whoever needs them, and this often varies between industries. This is one way.
    Regards Steven Gray
    Setting Out (Joinery Manufacturing)
    Autocad 2013LT
    Windows 7 professional
    Active Contributor
    JLeeSaxon
    10-19-2012 10:21 AM in reply to: steven-g
    Thanks. That's a lot cleaner that my first version. It still includes some rounded dimensions, though, which makes me nervous.
    How about what I've attached to this post? Does this work?
    Lee Saxon
    ELLIS
    Valued Mentor
    10-21-2012 10:39 AM in reply to: JLeeSaxon
    Rounding is again dependent on industry, I work for a shopfitting company Autocad works to 7 decimal places We do our drawings to the nearest half millimeter and then the joiners use a measuring tape that quite often varies by up to 3 or 4 millimeters per meter than another joiner. But engineering work to much tighter tolerances. I think it gives a much clearer impression with the measurements in your latest drawing but it goes outside normal standards, I would either include 2 drawings 1 without the fillets as you show and a second with the fillets detailed, or with a single drawing but extend your lines with a dotted line beyond the fillets to the corners. However you decide to show the information most often comes down to your industry and it is not worth trying to change how information is usually standardized as all your co-workers expect information in a certain way.
    Regards Steven Gray
    Autocad 2013LT
