Drafting Techniques
Drafting Techniques
jbcanam
Message 1 of 6 (15,860 Views)
Convert text to polylines
15860 Views, 5 Replies
02-27-2007 03:16 AM
I currently am using AutoCAD 2007 integrated with Microvellum and would like to know if there is a way to convert text to polylines as Microvellum will only recognize polylines when nesting. Right now I insert text and then have to outline it using th polyline command. This is slow and tedious. Is there a way to convert text to polylines?Any help in this matter would be greatly appreciated.
Distinguished Contributor
LLIB789
Message 2 of 6 (15,860 Views)
Re: Convert text to polylines
02-27-2007 04:05 AM in reply to: jbcanam
If you have express tools you can use this command.. TXTEXP The polylines that are formed are not joined though. If you need them joined you will have to do a pedit after..
Hugh_Compton
Message 3 of 6 (15,860 Views)
02-27-2007 04:50 AM in reply to: jbcanam
It is a good idea to use a font such as Arial as you will then be able to extrude the text to make 3D text. Fonts such as Simplex aren't extrudable without extra work.
CAD Pipe Fittings - http://www.herculedesign.com/
teiarch
Message 4 of 6 (15,860 Views)
02-27-2007 07:01 AM in reply to: jbcanam
Try the Elevation command on SHX fonts....
New Member
paul
Message 5 of 6 (7,179 Views)
04-25-2013 11:10 PM in reply to: LLIB789
it doesn`t work ?
*Expert Elite*
Charles_Shade
Message 6 of 6 (7,167 Views)
04-26-2013 04:35 AM in reply to: paul
Search these Forums for (and excuse me if I get this a bit mixed up) Exploding text, DXFOUT, DXFIN and more.
There are discusssions on doing such a thing to get Text entities broken down.
Roundtripping thru R14 may be a part of it as well.
Sorry to be so limited in this response.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Announcements
Need installation help?
