AutoCAD Forum
Closed spline with given length
5 REPLIES 5
smbdelse
973 Views, 5 Replies
I'm trying to find a way of drawing closed splines of specific length. To better describe what I need: I want to draw a biathlon track. Measures of track are specified, but how to draw this using a spline? I know that I can set length of open spline, but what with closed loops? Any ideas?
5 REPLIES 5
PaulMunford
in reply to: smbdelse
Couldn't you draw it using lines and arcs? You can allways convert a Polyline to a spline later?
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
3wood
in reply to: PaulMunford
Spline can be converted into polyline as well.
Kent1Cooper
Can you draw something of a shape you like, at any size, find its length, and scale the whole thing by the ratio of the desired length to the actual?
(command
  "_.scale"
  theSpline ; entity name
  (vlax-curve-getStartPoint theSpline)
    ;; or some other definable base point, possibly middle of bounding box, or User-specified
    theDesiredLength
    (vlax-curve-getDistAtParam theSpline (vlax-curve-getEndParam theSpline)); current total length
); command
Kent Cooper, AIA
smbdelse
in reply to: Kent1Cooper
It's the best solution for now. PaulMunford, 3wood: it's not what I need. Imagine that as a loop tied from a cord of a specific length that I can compose on a plan like I need. Building track from separated lines, splines, polylines, arcs or whatever doesn't solve the problem, it still needs too much effort.
PaulMunford
This sounds like a job for 2D geometric constraints 😉
”Boost
