• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DesignScript
    *Expert Elite*
    Some more curves
    287 Views, 4 Replies
    10-24-2012 03:26 AM
    DesignScript is relatively poor in native curves (Line, Arc, Circle and BSplineCurve).
    I thought it might be interesting to define some others.
    I tried to do this as classes with constructors, these classes may be required to evolve with the addition of new features.
    The
    generated curves are spline whose control points or smoothing are calculated from the equations of these curves.
    The Catenary, Ellipse, EllpticalArc and Parabola classes:
    import("ProtoGeometry.dll");
    import("Math.dll");
    class Catenary
        Curve : Curve;
        Chord : double;
        Param : double;
        Sagitta : double;
        Length : double;
        def argCosh(x : double)
            return = Math.Log(x + Math.Sqrt(x * x - 1));
        constructor FromChordParam(chord : double, param : double, numPts : int)
            Chord = chord;
            Param = param;
            Sagitta = param * Math.Cosh(chord / (2 * param)) - param;
            Length = 2 * param * Math.Sinh(chord / (2 * param));
            x = chord / -2..chord / 2..#numPts;
            y = param * Math.Cosh(x / param);
            Curve = BSplineCurve.ByPoints(Point.ByCoordinates(x, y, 0));
        constructor FromLenthSagitta(length : double, sagitta : double, numPts : int)
            Length = length;
            Sagitta = sagitta;
            Param = (length * length - 4 * sagitta * sagitta) / (8 * sagitta);
            Chord = 2 * Param * argCosh((sagitta + Param) / Param);
            x = Chord / -2..Chord / 2..#numPts;
            y = Param * Math.Cosh(x / Param);
    } class Ellipse { Curve : Curve; constructor FromRadii(majRadius : double, minRadius : double) { Curve = Circle.ByCenterPointRadius(Point.ByCoordinates(0, 0, 0), 1) .Transform(CoordinateSystem.WCS, CoordinateSystem.Identity().Scale(majRadius, minRadius, 1)); } } class EllipticalArc { Curve : Curve; constructor FromRadii(majRadius : double, minRadius : double, startAngle : double, sweepAngle : double) { endAngle = startAngle + sweepAngle; startParam = Math.Atan(majRadius * Math.Tan(startAngle) / minRadius); endParam = Math.Atan(majRadius * Math.Tan(endAngle) / minRadius); [Imperative] { if (startAngle == 0 || startAngle == 90 || startAngle == 180 || startAngle == 270 || startAngle == 360) startParam = startAngle; else if (startAngle > 90 && startAngle < 270) startParam = startParam + 180; if (endAngle == 0 || endAngle == 90 || endAngle == 180 || endAngle == 270 || endAngle == 360) endParam = endAngle; else if (endAngle > 90 && endAngle < 270) endParam = endParam + 180; if (endParam <= startParam) endParam = endParam + 360; } Curve = Arc.ByCenterPointRadiusAngle(Point.ByCoordinates(0, 0, 0), 1, startParam, endParam - startParam, Vector.ByCoordinates(0, 0, 1)) .Transform(CoordinateSystem.WCS, CoordinateSystem.Identity().Scale(majRadius, minRadius, 1)); } } class Parabola
        Curve : Curve;
        Focus : Point;
        constructor FromChordSagitta(chord : double, sagitta : double, numPts : int, focusVisible : bool)
            a = 4 * sagitta / (chord * chord);
            Focus = Point.ByCoordinates(0, 1 / (4 * a), 0).SetVisibility(focusVisible);
            x = chord / - 2..chord / 2..#numPts;
            y = a * x * x;
    Using examples
    Ellipses with incremented major axis.
    el = Ellipse.FromRadii(30..80..5, 30);
    Parabolas with decremented chords and incrmented sagittas.
    parabs = Parabola.FromChordSagitta(200..100..-10, 20..120..10, 19, false);
    Catenaries with incremented params.
    Each curve is moved so that start and end point lies ont the X axis. This is done using the Param and Sagitta properties of the Catenary instance.
    def catenar(chord : double, param : double, numPts : int)
        cat = Catenary.FromChordParam(chord, param, numPts);
        return = cat.Curve.Translate(0, -cat.Param - cat.Sagitta, 0);
    cats = catenar(160, 35..75..#10, 19);
    Gilles Chanteau
    Please use plain text.
    Member
    Re: Some more curves
    10-24-2012 06:08 AM in reply to: _gile
    Thanks!
    These definitions are very useful.
    Active Member
    10-30-2012 04:29 PM in reply to: _gile
    This is great! How did you find writing your own classes? Any surprises?
    Luke
    *Expert Elite*
    10-31-2012 02:26 PM in reply to: luke
    Thanks Luke.
    I found an example of class in the tutorial and try to build my own ones.
    Gilles Chanteau
    *Expert Elite*
    11-01-2012 11:37 AM in reply to: _gile
    One more: a cylindrical helix.
    The constructor arguments are:
    • the radius
    • the total height
    • the total angle, if the input is negative the helix turns clockwise
    import("Math.dll");
    class Helix
        Curve : Curve;
        constructor FromRadiusHeightAngle(radius : double, height : double, totalAngle : double)
            pi = 3.141592653589793;
            numPts = Math.Abs(Math.Round(totalAngle / 15)) + 1;
            step = height / (numPts - 1);
            ccw = Math.Sign(totalAngle);
            tanZ = (180 * height) / (pi * totalAngle * radius);
            startTan = Vector.ByCoordinates(0, ccw, ccw * tanZ);
            endTan = Vector.ByCoordinates(ccw * -Math.Sin(totalAngle), ccw * Math.Cos(totalAngle), ccw * tanZ);
            x = radius * Math.Cos(0 .. totalAngle .. #numPts);
            y = radius * Math.Sin(0 .. totalAngle .. #numPts);
            z = step * (0 .. numPts);
            Curve = BSplineCurve.ByPoints(Point.ByCoordinates(x, y, z), startTan, endTan);
    Gilles Chanteau
