DesignScript
Message 1 of 5 (372 Views)
Some more curves
372 Views, 4 Replies
10-24-2012 03:26 AM
DesignScript is relatively poor in native curves (Line, Arc, Circle and BSplineCurve).
I thought it might be interesting to define some others.
I tried to do this as classes with constructors, these classes may be required to evolve with the addition of new features.
The
generated curves are spline whose control points or smoothing are calculated from the equations of these curves.
The Catenary, Ellipse, EllpticalArc and Parabola classes:
import("ProtoGeometry.dll");
import("Math.dll");
class Catenary
    Curve : Curve;
    Chord : double;
    Param : double;
    Sagitta : double;
    Length : double;
    def argCosh(x : double)
        return = Math.Log(x + Math.Sqrt(x * x - 1));
    constructor FromChordParam(chord : double, param : double, numPts : int)
        Chord = chord;
        Param = param;
        Sagitta = param * Math.Cosh(chord / (2 * param)) - param;
        Length = 2 * param * Math.Sinh(chord / (2 * param));
        x = chord / -2..chord / 2..#numPts;
        y = param * Math.Cosh(x / param);
        Curve = BSplineCurve.ByPoints(Point.ByCoordinates(x, y, 0));
    constructor FromLenthSagitta(length : double, sagitta : double, numPts : int)
        Length = length;
        Sagitta = sagitta;
        Param = (length * length - 4 * sagitta * sagitta) / (8 * sagitta);
        Chord = 2 * Param * argCosh((sagitta + Param) / Param);
        x = Chord / -2..Chord / 2..#numPts;
        y = Param * Math.Cosh(x / Param);
} class Ellipse { Curve : Curve; constructor FromRadii(majRadius : double, minRadius : double) { Curve = Circle.ByCenterPointRadius(Point.ByCoordinates(0, 0, 0), 1) .Transform(CoordinateSystem.WCS, CoordinateSystem.Identity().Scale(majRadius, minRadius, 1)); } } class EllipticalArc { Curve : Curve; constructor FromRadii(majRadius : double, minRadius : double, startAngle : double, sweepAngle : double) { endAngle = startAngle + sweepAngle; startParam = Math.Atan(majRadius * Math.Tan(startAngle) / minRadius); endParam = Math.Atan(majRadius * Math.Tan(endAngle) / minRadius); [Imperative] { if (startAngle == 0 || startAngle == 90 || startAngle == 180 || startAngle == 270 || startAngle == 360) startParam = startAngle; else if (startAngle > 90 && startAngle < 270) startParam = startParam + 180; if (endAngle == 0 || endAngle == 90 || endAngle == 180 || endAngle == 270 || endAngle == 360) endParam = endAngle; else if (endAngle > 90 && endAngle < 270) endParam = endParam + 180; if (endParam <= startParam) endParam = endParam + 360; } Curve = Arc.ByCenterPointRadiusAngle(Point.ByCoordinates(0, 0, 0), 1, startParam, endParam - startParam, Vector.ByCoordinates(0, 0, 1)) .Transform(CoordinateSystem.WCS, CoordinateSystem.Identity().Scale(majRadius, minRadius, 1)); } } class Parabola
    Curve : Curve;
    Focus : Point;
    constructor FromChordSagitta(chord : double, sagitta : double, numPts : int, focusVisible : bool)
        a = 4 * sagitta / (chord * chord);
        Focus = Point.ByCoordinates(0, 1 / (4 * a), 0).SetVisibility(focusVisible);
        x = chord / - 2..chord / 2..#numPts;
        y = a * x * x;
Using examples
Ellipses with incremented major axis.
el = Ellipse.FromRadii(30..80..5, 30);
Parabolas with decremented chords and incrmented sagittas.
parabs = Parabola.FromChordSagitta(200..100..-10, 20..120..10, 19, false);
Catenaries with incremented params.
Each curve is moved so that start and end point lies ont the X axis. This is done using the Param and Sagitta properties of the Catenary instance.
def catenar(chord : double, param : double, numPts : int)
    cat = Catenary.FromChordParam(chord, param, numPts);
    return = cat.Curve.Translate(0, -cat.Param - cat.Sagitta, 0);
cats = catenar(160, 35..75..#10, 19);
Gilles Chanteau
Member
Message 2 of 5 (364 Views)
Re: Some more curves
10-24-2012 06:08 AM in reply to: _gile
Thanks!
These definitions are very useful.
Active Member
Message 3 of 5 (321 Views)
10-30-2012 04:29 PM in reply to: _gile
This is great! How did you find writing your own classes? Any surprises?
Luke
Message 4 of 5 (310 Views)
10-31-2012 02:26 PM in reply to: luke
Thanks Luke.
I found an example of class in the tutorial and try to build my own ones.
Gilles Chanteau
Message 5 of 5 (300 Views)
11-01-2012 11:37 AM in reply to: _gile
One more: a cylindrical helix.
The constructor arguments are:
  • the radius
  • the total height
  • the total angle, if the input is negative the helix turns clockwise
import("Math.dll");
class Helix
    Curve : Curve;
    constructor FromRadiusHeightAngle(radius : double, height : double, totalAngle : double)
        pi = 3.141592653589793;
        numPts = Math.Abs(Math.Round(totalAngle / 15)) + 1;
        step = height / (numPts - 1);
        ccw = Math.Sign(totalAngle);
        tanZ = (180 * height) / (pi * totalAngle * radius);
        startTan = Vector.ByCoordinates(0, ccw, ccw * tanZ);
        endTan = Vector.ByCoordinates(ccw * -Math.Sin(totalAngle), ccw * Math.Cos(totalAngle), ccw * tanZ);
        x = radius * Math.Cos(0 .. totalAngle .. #numPts);
        y = radius * Math.Sin(0 .. totalAngle .. #numPts);
        z = step * (0 .. numPts);
        Curve = BSplineCurve.ByPoints(Point.ByCoordinates(x, y, z), startTan, endTan);
Gilles Chanteau
You are not logged in.
Visit Autodesk Labs
Autodesk Labs is home for new prototypes, experiments, applications, and technologies.
Ask the Community
