DesignScript
Message 1 of 9 (748 Views)
Accepted Solution
Moebius Strip: My first attempt
748 Views, 8 Replies
10-20-2012 05:41 AM
My first attempt in DesignScript.
import("ProtoGeometry.dll");
import("Math.dll");
num_pts = 100;
s = 20;
t = 0..360..#num_pts;
R = 100;
x = (R + s * (Math.Cos(t / 2))) * (Math.Cos(t));
y = (R + s * (Math.Cos(t / 2))) * (Math.Sin(t));
z = s * Math.Sin(t / 2);
p1 = Point.ByCoordinates(x, y, z);
int_curve = BSplineCurve.ByControlVertices(p1,1);
int_curve.Color = Color.ByARGB(255, 0, 0, 255);
s2 = -20;
t2 = t;
R2 = R;
x2 = (R2 + s2 * (Math.Cos(t2 / 2))) * (Math.Cos(t2));
y2 = (R2 + s2 * (Math.Cos(t2 / 2))) * (Math.Sin(t2));
z2 = s2 * Math.Sin(t2 / 2);
p2 = Point.ByCoordinates(x2, y2, z2);
//x = print(x,y,z);
int_curve2 = BSplineCurve.ByControlVertices(p2,1);
int_curve2.Color = Color.ByARGB(255, 0, 255, 0);
l[1..num_pts] = Line.ByStartPointEndPoint(p1, p2);
loft = Surface.LoftFromCrossSections({ l[1..(num_pts-1)] });
http://inventorfaq.blogspot.de/2012/10/mobius-band-mit-autodesk-design-script.html
Juergen
Active Member
Message 2 of 9 (736 Views)
Re: Moebius Strip: My first attempt
10-20-2012 01:16 PM in reply to: jwagner
Dear Jurgen,
This is really great to see :smileyhappy:
If I might make a few suggestions?
We can adjust this line
to be
l = Line.ByStartPointEndPoint(p1, p2);
and designScript will just turn l into a collection automatically. This also means that we can avoid the 'first element is null' problem
and then the next line becomes:
loft = Surface.LoftFromCrossSections({ l[0..num_pts - 2], l[1..num_pts - 1] });
Which is a list of things to loft from -> to. It seems perhaps the arguments of this method could do with a bit more explaining?
But - this gives the complete script as:
import("Math.dll");
num_pts = 100;
s = 20;
R = 100;
s2 = -20;
t2 = t;
R2 = R;
//x = print(x,y,z);
Which produces a complete mobius band. Is that what you were aiming for?
On another note - I see in your blog, you say DesignScript crashes often. I'm sorry to hear that. Could you send me a screenshot? We're aware of one crashing bug, but I'd like to make sure there isn't something else we've missed.
Thanks again - this is a great start and a lovely little script :smileyhappy:
Luke
Message 3 of 9 (722 Views)
10-21-2012 01:52 AM in reply to: luke
Hi Luke,
thank you for your help to complete the script. Works great!
And because of teh crash: I get a crash after runing a script many times. Error:
but: I don't have SP1 für ACAD Mechanical 2013 installed! Will install today.
In addition to your improvement I have made this change to the script:
s2 = s * -1;
because s2 must be -s :smileywink:
This is my final script with your improvements:
import("Math.dll");
num_pts = 100;
s = 20;
R = 100;
s2 = s * -1;
t2 = t;
R2 = R;
//x = print(x,y,z);
l= Line.ByStartPointEndPoint(p1, p2);
Thanks again!
Juergen
*Expert Elite*
Message 4 of 9 (718 Views)
10-21-2012 02:01 AM in reply to: jwagner
Very nice.
My 2 cts: the point collections can be computed by a single function which argument is s or -s (I removed the splines as they're not used to build the surfaces)
import("Math.dll");
num_pts = 100;
s = 20;
R = 100;
def pts(s : double)
    return = Point.ByCoordinates(x, y, z);
l = Line.ByStartPointEndPoint(pts(s), pts(-s));
Gilles Chanteau
Message 5 of 9 (717 Views)
10-21-2012 02:02 AM in reply to: jwagner
because of the crash: When I shade the drawing und run the script again (1-2 times) I get the system error.
Same problem after applying SP1 for AutoCAD Mechanical 2013.
Employee
Message 6 of 9 (617 Views)
11-08-2012 12:41 AM in reply to: jwagner
Sorry to know that you are facing some crash while running design script. A new update (version 0.3.24.5026) for DesignScript is available, hopefully this update fixes your crash issue.
New Member
pointclouding
Message 7 of 9 (593 Views)
11-14-2012 07:52 PM in reply to: jwagner
NICE WORK!
THANK YOU FOR SHARING!
*Expert Elite*
Message 8 of 9 (421 Views)
02-23-2013 05:11 PM in reply to: pointclouding
Playing with this in .NET at TheSwamp, it looks like we (kaefer and I) found a way to create a single closed entity (Solid3d)
import("Math.dll");
numPts = 60;
halfWid = 20;
angle = 0..360..#numPts;
radius = 100;
width = 2; def pts(halfWid : double) { x = (radius + halfWid * (Math.Cos(angle / 2))) * (Math.Cos(angle)); y = (radius + halfWid * (Math.Cos(angle / 2))) * (Math.Sin(angle)); z = halfWid * Math.Sin(angle / 2); return = Point.ByCoordinates(x, y, z); } lines = Line.ByStartPointEndPoint(pts(halfWid), pts(-halfWid)); lines.SetVisibility(false); surfs = Surface.LoftFromCrossSections({ lines[0..numPts / 2], lines[numPts / 2..numPts] }); surfs.Visible = false; solids = surfs.Thicken(width, true); solid = solids[0].Union(solids[1]);
Gilles Chanteau
Board Manager
Message 9 of 9 (389 Views)
03-04-2013 06:54 AM in reply to: _gile
Thanks for sharing. This is what technology previews are all about.
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
You are not logged in.
Announcements
Visit Autodesk Labs
Autodesk Labs is home for new prototypes, experiments, applications, and technologies.
Need installation help?
Ask the Community
