• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DesignScript
    Moebius Strip: My first attempt
    474 Views, 8 Replies
    10-20-2012 05:41 AM
    My first attempt in DesignScript.
    import("ProtoGeometry.dll");
    import("Math.dll");
    num_pts = 100;
    s = 20;
    t = 0..360..#num_pts;
    R = 100;
    x = (R + s * (Math.Cos(t / 2))) * (Math.Cos(t));
    y = (R + s * (Math.Cos(t / 2))) * (Math.Sin(t));
    z = s * Math.Sin(t / 2);
    p1 = Point.ByCoordinates(x, y, z);
    int_curve = BSplineCurve.ByControlVertices(p1,1);
    int_curve.Color = Color.ByARGB(255, 0, 0, 255);
    s2 = -20;
    t2 = t;
    R2 = R;
    x2 = (R2 + s2 * (Math.Cos(t2 / 2))) * (Math.Cos(t2));
    y2 = (R2 + s2 * (Math.Cos(t2 / 2))) * (Math.Sin(t2));
    z2 = s2 * Math.Sin(t2 / 2);
    p2 = Point.ByCoordinates(x2, y2, z2);
    //x = print(x,y,z);
    int_curve2 = BSplineCurve.ByControlVertices(p2,1);
    int_curve2.Color = Color.ByARGB(255, 0, 255, 0);
    l[1..num_pts] = Line.ByStartPointEndPoint(p1, p2);
    loft = Surface.LoftFromCrossSections({ l[1..(num_pts-1)] });
    http://inventorfaq.blogspot.de/2012/10/mobius-band-mit-autodesk-design-script.html
    Juergen
    Please use plain text.
    Active Member
    Re: Moebius Strip: My first attempt
    10-20-2012 01:16 PM in reply to: jwagner
    Dear Jurgen,
    This is really great to see :smileyhappy:
    If I might make a few suggestions?
    We can adjust this line
    to be
    l = Line.ByStartPointEndPoint(p1, p2);
    and designScript will just turn l into a collection automatically. This also means that we can avoid the 'first element is null' problem
    and then the next line becomes:
    loft = Surface.LoftFromCrossSections({ l[0..num_pts - 2], l[1..num_pts - 1] });
    Which is a list of things to loft from -> to. It seems perhaps the arguments of this method could do with a bit more explaining?
    But - this gives the complete script as:
    import("Math.dll");
    num_pts = 100;
    s = 20;
    R = 100;
    s2 = -20;
    t2 = t;
    R2 = R;
    //x = print(x,y,z);
    Which produces a complete mobius band. Is that what you were aiming for?
    On another note - I see in your blog, you say DesignScript crashes often. I'm sorry to hear that. Could you send me a screenshot? We're aware of one crashing bug, but I'd like to make sure there isn't something else we've missed.
    Thanks again - this is a great start and a lovely little script :smileyhappy:
    Luke
    10-21-2012 01:52 AM in reply to: luke
    Hi Luke,
    thank you for your help to complete the script. Works great!
    And because of teh crash: I get a crash after runing a script many times. Error:
    but: I don't have SP1 für ACAD Mechanical 2013 installed! Will install today.
    In addition to your improvement I have made this change to the script:
    s2 = s * -1;
    because s2 must be -s :smileywink:
    This is my final script with your improvements:
    import("Math.dll");
    num_pts = 100;
    s = 20;
    R = 100;
    s2 = s * -1;
    t2 = t;
    R2 = R;
    //x = print(x,y,z);
    l= Line.ByStartPointEndPoint(p1, p2);
    Thanks again!
    Juergen
    10-21-2012 02:01 AM in reply to: jwagner
    Very nice.
    My 2 cts: the point collections can be computed by a single function which argument is s or -s (I removed the splines as they're not used to build the surfaces)
    import("Math.dll");
    num_pts = 100;
    s = 20;
    R = 100;
    def pts(s : double)
        return = Point.ByCoordinates(x, y, z);
    l = Line.ByStartPointEndPoint(pts(s), pts(-s));
    Gilles Chanteau
    10-21-2012 02:02 AM in reply to: jwagner
    because of the crash: When I shade the drawing und run the script again (1-2 times) I get the system error.
    Same problem after applying SP1 for AutoCAD Mechanical 2013.
    Employee
    11-08-2012 12:41 AM in reply to: jwagner
    Sorry to know that you are facing some crash while running design script. A new update (version 0.3.24.5026) for DesignScript is available, hopefully this update fixes your crash issue.
    New Member
    pointclouding
    11-14-2012 07:52 PM in reply to: jwagner
    NICE WORK!
    THANK YOU FOR SHARING!
    02-23-2013 05:11 PM in reply to: pointclouding
    Playing with this in .NET at TheSwamp, it looks like we (kaefer and I) found a way to create a single closed entity (Solid3d)
    import("Math.dll");
    numPts = 60;
    halfWid = 20;
    angle = 0..360..#numPts;
    radius = 100;
    width = 2; def pts(halfWid : double) { x = (radius + halfWid * (Math.Cos(angle / 2))) * (Math.Cos(angle)); y = (radius + halfWid * (Math.Cos(angle / 2))) * (Math.Sin(angle)); z = halfWid * Math.Sin(angle / 2); return = Point.ByCoordinates(x, y, z); } lines = Line.ByStartPointEndPoint(pts(halfWid), pts(-halfWid)); lines.SetVisibility(false); surfs = Surface.LoftFromCrossSections({ lines[0..numPts / 2], lines[numPts / 2..numPts] }); surfs.Visible = false; solids = surfs.Thicken(width, true); solid = solids[0].Union(solids[1]);
    Gilles Chanteau
    Board Manager
    03-04-2013 06:54 AM in reply to: _gile
    Thanks for sharing. This is what technology previews are all about.
    Scott Sheppard
    Program Manager
    Autodesk Labs
