DesignScript
Active Member
Gytaco
Message 1 of 6 (275 Views)
Issue with Transparency
275 Views, 5 Replies
10-10-2012 04:53 AM
I have created a cylinder and applied a color as shown
cyl.Color = Color.ByARGB(
255, 0, 255, 0);
However the transparency does not seem to apply to the object.
I am using different visual styles is there a specific option I should be using??
Employee
sharadjaiswal
Message 2 of 6 (259 Views)
Re: Issue with Transparency
10-11-2012 06:37 AM in reply to: Gytaco
You may try x-ray visual style to create transparent objects.
New Member
OceaniaPrecision
Message 3 of 6 (244 Views)
10-11-2012 05:27 PM in reply to: Gytaco
I'm encountering the same issue.  The layer trasparency setting is overriding the ARGB alpha setting.  I'm just starting out in DesignScript, so I haven't dug vary far into this, however, the manual states:  "For a Color’s alpha, 0 means the object will be completely transparent, while 255 means the object will be completely opaque."
Active Member
Gytaco
Message 4 of 6 (241 Views)
10-11-2012 05:39 PM in reply to: OceaniaPrecision
Exactly Even when I adjust the value to 0 or anything in between it makes no difference. ______________________________________________________________________ The information contained in this email and any files transmitted with it are confidential and are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please promptly notify the sender by reply email and then delete the email and destroy any printed copy. Further, if you have received this email in error, you must not disclose or use the information contained therein for any purpose whatsoever. ADG Engineers will assume no responsibility for the accuracy, adequacy, and integrity of the files, and recommends that the files be thoroughly screened for viruses prior to installation. ______________________________________________________________________
Employee
sharadjaiswal
Message 5 of 6 (232 Views)
10-11-2012 09:20 PM in reply to: Gytaco
It seems that Color property on AutoCAD entity deson't have alpha value, but it has a separate Transparency property. And the default value for transparency is set ByLayer hence changing layer transparency overrides entity transparency.
So I think the alpha value in DesignScript should be mapped to Transparency property of the entity. This seems like a limitation at this point.
Employee
sharadjaiswal
Message 6 of 6 (168 Views)
11-05-2012 07:26 PM in reply to: sharadjaiswal
Please try the new version ( 0.3.24.5026) of DesignScript, this issue is fixed.
You can see the "Dwonload new update" notification on top right corner of DesignScript Editor. Clicking the notification button will guide you thru the migration to new update.
You are not logged in.
Visit Autodesk Labs
Autodesk Labs is home for new prototypes, experiments, applications, and technologies.
Ask the Community
