• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    DesignScript
    Member
    Gytaco
    Issue with Transparency
    202 Views, 5 Replies
    10-10-2012 04:53 AM
    I have created a cylinder and applied a color as shown
    cyl.Color = Color.ByARGB(
    255, 0, 255, 0);
    However the transparency does not seem to apply to the object.
    I am using different visual styles is there a specific option I should be using??
    Please use plain text.
    Employee
    Re: Issue with Transparency
    10-11-2012 06:37 AM in reply to: Gytaco
    You may try x-ray visual style to create transparent objects.
    New Member
    OceaniaPrecision
    10-11-2012 05:27 PM in reply to: Gytaco
    I'm encountering the same issue.  The layer trasparency setting is overriding the ARGB alpha setting.  I'm just starting out in DesignScript, so I haven't dug vary far into this, however, the manual states:  "For a Color’s alpha, 0 means the object will be completely transparent, while 255 means the object will be completely opaque."
    Member
    Gytaco
    10-11-2012 05:39 PM in reply to: OceaniaPrecision
    Exactly Even when I adjust the value to 0 or anything in between it makes no difference. ______________________________________________________________________ The information contained in this email and any files transmitted with it are confidential and are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please promptly notify the sender by reply email and then delete the email and destroy any printed copy. Further, if you have received this email in error, you must not disclose or use the information contained therein for any purpose whatsoever. ADG Engineers will assume no responsibility for the accuracy, adequacy, and integrity of the files, and recommends that the files be thoroughly screened for viruses prior to installation. ______________________________________________________________________
    Employee
    10-11-2012 09:20 PM in reply to: Gytaco
    It seems that Color property on AutoCAD entity deson't have alpha value, but it has a separate Transparency property. And the default value for transparency is set ByLayer hence changing layer transparency overrides entity transparency.
    So I think the alpha value in DesignScript should be mapped to Transparency property of the entity. This seems like a limitation at this point.
    Employee
    11-05-2012 07:26 PM in reply to: sharadjaiswal
    Please try the new version ( 0.3.24.5026) of DesignScript, this issue is fixed.
    You can see the "Dwonload new update" notification on top right corner of DesignScript Editor. Clicking the notification button will guide you thru the migration to new update.
