DesignScript
Member
mark
Message 1 of 5 (953 Views)
Create Catenary Curves with DesignScript?
953 Views, 4 Replies
10-20-2012 01:16 PM
I have a funicular fireplace design that I created using Rhino Grasshopper.
The design and the Grasshopper definition screen capture are attached. Grasshopper has a catenary curve component that creates a spline curve in Rhino. All you need is two points and a number slider to drive the length of the curve.
The baked geometry that I created in Rhino was subsequently imported into AutoCAD where I solid modeled the fireplace and rendered it.
How would you tackle this same design problem with DesignScript?
Thanks.
_gile
Message 2 of 5 (921 Views)
Re : Create Catenary Curves with DesignScript?
10-21-2012 05:57 AM in reply to: mark
I do not know Grasshopper, but may be this to start with DesignScript:
import("ProtoGeometry.dll");
numPts = 17;
def parabola(width : double, height : double)
    a = -4 * height / (width * width);
    x = width / -2..width / 2..#numPts;
    y = 0;
    z = a * x * x + height;
    return = BSplineCurve.ByPoints(Point.ByCoordinates(x, y, z));
spl1 = parabola(10, 6);
spl2 = parabola(12, 8);
Gilles Chanteau
Member
mark
Message 3 of 5 (896 Views)
10-22-2012 10:47 AM in reply to: _gile
Hi _gile,
Thank you for your quick response!
I ran your script and the results are attached. This is a very nice approximation of my fireplace geometry.
The reason I say approximation is because a parabola is visually very similar to a catenary but mathematically very different. The catenary also has a very important structural attribute in that it creates a compression only arch that is structurally stable. This is not true of a parabola. Here's more information about the differences.
http://mathforum.org/library/drmath/view/65729.html
http://en.wikipedia.org/wiki/Catenary
Please add the catenary curve to the geometry library so that you can use DesignScript for funicular form finding.
Thanks.
_gile
Message 4 of 5 (882 Views)
Re : Re : Create Catenary Curves with DesignScript?
10-22-2012 01:48 PM in reply to: mark
This one  draws a true catenary curve.
You'd have to play with the param argument to find the height that suits you according to a given width.
import("Math.dll");
def catenary(width : double, param : double)
    height = param * Math.Cosh(width / (2 * param));
    x = width / -2..width / 2..#17;
    y = 0;
    z = param * Math.Cosh(x / param) - height;
cat1 = catenary(100, -28);
cat2 = catenary(120, -30);
Gilles Chanteau
Member
mark
Message 5 of 5 (878 Views)
10-22-2012 02:59 PM in reply to: _gile
Thanks, that was fast!
Please see the attached 2 page PDF for a comparison of the parabola and the catenary definitions. I have a question about how you wrote the numPts variable in both definitions.
Otherwise, I consider this problem solved.
Thanks again!
You are not logged in.
Visit Autodesk Labs
Autodesk Labs is home for new prototypes, experiments, applications, and technologies.
Ask the Community
