DesignScript
Active Member
Gytaco
Message 1 of 4 (228 Views)
Change Naming Conventions - Floor,Ceiling
228 Views, 3 Replies
10-16-2012 09:15 PM
Hey Guys
I knwo this is early days so hopefully things like this can change without too much issue.
I really think "Floor" & "Ceiling" are not good keynames in the context of design scripting.
Many Many times are people going to use this tool to define floors and ceilings and this use of terminology could confuse.
Surely some like Math.RoundUp and Math.RoundDown are preferrable, not too mention obvious as to the intent of the function??
I thought one of key elements was to bring people without any programming background into this slowly and easily, using computer terminology should be avoided where possible and this is an obvious case for new learners.
Is there any background as to why the terminology is in conflict with what Architects and Engineers will use to describe many objects???
Active Member
luke
Message 2 of 4 (212 Views)
Re: Change Naming Conventions - Floor,Ceiling
10-17-2012 10:30 AM in reply to: Gytaco
Thanks for your suggestion :smileyhappy: We'll certainly consider that :smileyhappy:
New Member
tobiasjewson
Message 3 of 4 (156 Views)
11-19-2012 06:36 AM in reply to: Gytaco
My vote is for keeping the names as they are. Floor and Ceiling are standard mathematical notation (see http://en.wikipedia.org/wiki/Floor_and_ceiling_functions) and the names are used in just about every other programming language. Since the functions are encapsulated in the Math class there shouldn't be any ambiguity between a user defined variable named Floor and the Math.Floor function.
I my view it's is more confusing to change such established names, but I suppose it all comes down to the intended target audience as mentioned above.
- Tobias
Active Member
luke
Message 4 of 4 (152 Views)
11-19-2012 06:40 AM in reply to: Gytaco
Well, if nothing else, they need moving out of the global namespace and into the Math namespace :smileyhappy: But that will need to wait a bit until better support for namespacing comes along...
Thanks for your input anyhow
You are not logged in.
Announcements
Visit Autodesk Labs
Autodesk Labs is home for new prototypes, experiments, applications, and technologies.
Need installation help?
Ask the Community
