Hi ronniemac,
This sounds very much like a known issue we've been investigating for some time with hyperlinks to DWF files that are located on a network share [Defect ID = 786302].
Just to confirm, does the Word file contain simple hyperlinks to a DWF file that when clicked will open the file in the standalone Design Review application or is this a case where the DWF file is opened embedded within MS Word?
If you open the same DWF file in Standalone and click on the markup, does the same problem occur?
Thanks in advance for the additional information.
Scott Lillibridge, QA Manager
Extended Design Group
Autodesk, Inc.
